09-06-2011 11:14 PM - edited 03-03-2019 06:21 AM
Just wanted to double check
MT-RJ to MT-RJ ??
http://www.cisco.com/en/US/products/hw/switches/ps628/products_data_sheet09186a00801cfb71.html
Thank you
Alex Gibson
Solved! Go to Solution.
09-08-2011 04:48 AM
Hi Alex,
You will be able to get an MT-RJ-to-MT-RJ cable but then it is still not going to work.
The 2950C has 100FX-ports (FastEhernet) and the 2950SX has 1000SX ports (Gigabit).
The two ports are incompatible, they will not negotiate the link speed.
There will simply be no connection.
Probably not the answer you had hoped for. Sorry for that.
regards,
Leo
09-08-2011 04:48 AM
Hi Alex,
regards,
Leo
09-08-2011 01:33 PM
Thank you
No it's always good to know what can and can't be done.
I hate it when people tell you something that is wrong.
Can move to backup plan of connecting them via a 2950g with
the right gbics.
Thank you
