03-31-2004 11:12 AM - edited 03-02-2019 02:41 PM
In Cat3550, the ospf load balance with equal cost (2 routes) fail when change adjacency neighbor.
When neighbor is up the load balance don't work.
the workaround is:
clear ip route * or
clear ip ospf 100 process
04-02-2004 03:01 AM
Could you post a show ip route before and after the neighbor fails for the route you're having a problem with?
Russ.W
Log in to Community
