Catalyst3550 boot error, please help
lu.peng
There was an error "Non-free molecules were seen on the notify ring", when the system was booting. The system reloads for several times and then stoped there.
Did anybody meet such situation? Pls help.
Thanks a lot.
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(9)EA1a, RELEASE SOFTWARE (f
c1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 01-May-02 19:22 by antonino
Image text-base: 0x00003000, data-base: 0x00684C1C
Initializing flashfs...
flashfs[1]: 19 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 16128000
flashfs[1]: Bytes used: 8491520
flashfs[1]: Bytes available: 7636480
flashfs[1]: flashfs fsck took 15 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
Non-free molecules were seen on the notify ring.
POST: CPU Interface Tests : End, Status Failed
CPU Interface Queue Initialization Failedcisco WS-C3550-12T (PowerPC) processor (r
evision G0) with 65526K/8192K bytes of memory.
Processor board ID CAT0624Z10Q
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:E8:AB:8C:80
Motherboard assembly number: 73-5527-13
Power supply part number: 34-0967-01
Motherboard serial number: CAT06230G0G
Power supply serial number: DAB061408R1
Model revision number: G0
Motherboard revision number: B0
Model number: WS-C3550-12T
System serial number: CAT0624Z10Q
!!! WARNING: The switch is not usable !!!
Reason:
=== Flushing messages (00:00:20 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:20: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging outpu
t.
00:00:17: %SYS-2-NULLCHUNK: Memory requested from Null Chunk
-Process= "Init", ipl= 0, pid= 2
-Traceback= 182374 2870A4 297318 2776C0 19BE64 19BF14 F109C F125C 1A4B14
00:00:17: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
c1)
Unassigned Exception (0xA9B840)!
CPU Register Context:
Vector = 0x00A9B840 PC = 0x0027961C MSR = 0x20099030 CR = 0x28000000
LR = 0x00279600 CTR = 0x00196500 XER = 0x00000000
R0 = 0x00000000 R1 = 0x00A9B838 R2 = 0x00000000 R3 = 0x00001200
R4 = 0xFFFFFFFF R5 = 0xFEC0FEC0 R6 = 0xFEE00000 R7 = 0x00001030
R8 = 0x00009030 R9 = 0x908000A4 R10 = 0x000000F0 R11 = 0x00000000
R12 = 0x000003A8 R13 = 0xD5BFFEFF R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00A9B8B8 R23 = 0x00000000
R24 = 0x000003E8 R25 = 0x00006000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x00970000 R29 = 0x00000404 R30 = 0x00000400 R31 = 0x00000000
Stack trace:
PC = 0x0027961C, SP = 0x00A9B838
Frame 00: SP = 0x00A9B870 PC = 0x002795CC
Frame 01: SP = 0x00A9B8B0 PC = 0x0028D334
Frame 02: SP = 0x00A9B9D0 PC = 0x002FD6CC
Frame 03: SP = 0x00A9B9E8 PC = 0x002AFCE8
Frame 04: SP = 0x00000000 PC = 0x001A4B14
Prashanth Krishnappa
This switch has failed POST tests. It normally indicates a hardware failure. I suggest that you open a TAC Case
