CBWFQ and Encryption on ATM sub-interface
chan-kuen.hui
I have two 7200 router (IOS IP IPSEC 56 ver. 12.2(24)) with ATM interface connected together.
I have configured the sub-interface with crypto map and service-policy applied.
interface ATM4/0.1 point-to-point
ip address 10.1.1.1 255.255.255.252
pvc 1/101
vbr-nrt 512 512 32
encapsulation aal5snap
service-policy output policy1
crypto map map1
I use policy-map policy1 with 2 class-map.
class-map match-any class_1
match access-group 111
class-map match-any class_2
match access-group 112
policy-map policy1
class class_1
bandwidth 128
class class_2
bandwidth 192
class NETBIOS
bandwidth 64
class class-default
fair-queue
However, when i enable the crypto map, all traffic for policy-map will go to class class-default instead of class class_1 or class_2.
When I remove the crypto map, the traffic will go to the correct class class_1 or class_2.
Is there any other command requried?
Thanks and Regards,
Hui
micah
Hui,
Use the command "qos pre-classify" under your crypto map. Check out the link below:
http://cisco.com/en/US/netsol/ns340/ns394/ns171/ns109/networking_solutions_white_paper09186a0080189080.shtml
