07-22-2004 03:10 AM - edited 03-02-2019 05:14 PM
I bought two Cisco 836 with ADSL over RDSI for my office, I configured they with the Web enviroment and we can use all internet resources (http,pop3,etc) but only from LAN to WAN.
If I try to make NAT from WAN to any server that it's on my LAN I can make it only with one router because if I try to make this NAT in the two ones randomly one of the two units stop making NAT from WAN to LAN but it continue working from LAN to WAN.
I don't know why it happen but when it succeed I can't make a ping from the server to the router, after it succeed yes, the servers are Linux Red Hat 9, and I try to nat ports 80,443,110 and 25.
I need the two lines makeing nat because I make a load balancing with round robin of DNS.
Thanks for all
07-28-2004 01:18 AM
Any idea?
Thanks.
07-28-2004 02:54 AM
are you trying to use both 836 routers as exit points for all clients on your LAN ? It seems to me that this could cause the problems you describe, if you try to reach one of your inside machines from the outside, and that machine sends out the traffic through the other link, connectivity would be lost.
Can you post the configurations of both routers ?
GP
07-28-2004 03:43 AM
The configurations of the two Cisco 836 are, the only change is the public IP, the ETH0 IP and the hostname.
Using 2154 out of 131072 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname admin1
no logging buffered
enable secret xxxxx
username CRWS_Shashi privilege 15 password 7 (removed)
username admin1 password 7 (removed)
username CRWS_Gayatri privilege 15 password 7 (removed)
username sdm password 7 (removed)
no aaa new-model
ip subnet-zero
ip name-server 195.235.113.3
ip name-server 195.235.96.90
ip dhcp excluded-address 192.168.3.5
ip dhcp excluded-address 192.168.3.8
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description CRWS Generated text. Please do not delete this:192.168.3.6-255.255.255.0
ip address 192.168.3.6 255.255.255.0
ip nat inside
no ip mroute-cache
interface BRI0
no ip address
shutdown
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode etsi
interface ATM0.1 point-to-point
ip address (removed for security) 255.255.255.0
ip nat outside
pvc 8/32
encapsulation aal5snap
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip nat inside source list 102 interface ATM0.1 overload
ip nat inside source static tcp 192.168.3.5 25 interface ATM0.1 25
ip nat inside source static tcp 192.168.3.5 110 interface ATM0.1 110
ip nat inside source static tcp 192.168.3.8 80 interface ATM0.1 80
ip nat inside source static tcp 192.168.3.8 443 interface ATM0.1 443
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip route 192.168.3.0 255.255.255.0 Ethernet0
ip http server
ip http secure-server
access-list 102 permit ip 192.168.3.0 0.0.0.255 any
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
