Cisco AnyConnect and Cisco ASR 1000
j44mistry
We are currently using Cisco VPN Client for Windows 7 connecting to Cisco ASR 1000 and Cisco 3925 Routers.
To start using Cisco AnyConnect Client with existing Routers:-
1. Will the client still work with Router IOS ?
2. What additional configuration is required if not ?
viyuan700
Level 5
Level 5
VPN client you are using is Ipsec based client whereas Anyconnect Client is SSL based VPN.
1. Will the client still work with Router IOS ? Yes 3925 supports and  you need license. Also  IOS version  15.0 & above
2. What additional configuration is required if not ? As it is totally different yes need different configuration. you will need a certificate for you VPN address . Link below have some configuration ideas.
http://www.cisco.com/c/dam/en/us/td/docs/routers/access/cisco_router_and_security_device_manager/application/notes/WebVPN.pdf
Check for all required for Router based VPN. We are running on ASA.
http://www.cisco.com/c/en/us/products/collateral/security/ios-sslvpn/product_data_sheet0900aecd80405e25.html
What Anyconnect version can I use to work with Cisco 3925 IOS 15.x   ?
Please check your requirement and see what version would be the right for your scenario. Otherwise you can use the latest version . Such as if you need Windows 8 support then the first version which support is 3.1.04072 & later.
Please check the example using version 3.1.00495
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/904-cisco-router-anyconnect-webvpn.html
Thanks for additional info.
I have uploaded anyconnect pkg to router and configured as per instructions provided.
How do I download the client to windows from internet or do I have to do this from the Lan only ?   Do I just specify the gateway address of router using https ?
