07-05-2025 09:56 AM
Hello everyone,
I wonder if anyone have had a similar issue as the one I have been experiencing, I have create a Trunk port with dual link for redundancy and added as Po66 by example.
then created a sub interface with the IP 172.1.1.1/24 VLAN 66 zone: inside
But I m unable to ping the device attach to the inteface although is set as: 172.1.1.2/24 over VLAN 66
My enviroment topology links:
FRP - Spine Switch -> Leaf switch -> device (status: drop)
as reference I am connected as work station -> Leaf Switch -> Spine Switch -> Management servers -> VM -> Virtual FMC (status: OK)
I did tried packet tracer with a concerning result:
VLAN66(vrfid:0)
ACCESS-LIST (OK)
ROUTE-LOOKUP | No ECMP load balancing (OK)
OBJECT_GROUP_SEARCH (OK)
ACCESS-LIST (DROP)
QUESTION: do I ahve to create an access allow policy to allow this link on the interface? any idea please
Solved! Go to Solution.
07-05-2025 10:41 AM
Yes random IP
Later when you config any ACP use IP from ACP to check it.
Here as you mention there is no any ACP use any IP
But always remember in packet tracer dont use IP of any interface of FW
MHM
07-05-2025 09:56 AM
sorry the link is up but no traffic flowing
07-05-2025 10:03 AM
How you run packet tracer?
What is IP you use abd what is IP of interface
MHM
07-05-2025 10:30 AM
I have seclected the applicance then
Protocol: TCP
Source Type: ipv4 172.1.1.1
source port: http
inline tag: Empty
Eggress interface: VLAN66
VLAN: (grayout)
Destination type: ipv4 172.1.1.2
Destination port: http
Allow the simulated packet to trans... etc
07-05-2025 10:33 AM
If you use interface IP in packet tracer then you will get this result
Try do packet tracer again and dont use IP of any FPR interface
MHM
07-05-2025 10:38 AM
Thank you MHM,
But what you mean? the only options are IPv4 and 6 as FQND? jusy use a random IP?
07-05-2025 10:41 AM
Yes random IP
MHM
07-05-2025 10:58 AM
OH I DID NOT KNOW THAT!!
Thank you so much, all success it did connected
