Cisco router 1921 problem
Iaco
Beginner
Beginner
Hi All,
I have a problem on the router 1921 the infrastructure is as follows:
router isp -> sw -> sw -> router 1921 -> distributor
can someone help me to understand why I can't get to the distributor from the ISP router? this is how the 1921 is configured
boot-start-marker
boot-end-marker
enable secret 4 xxxxx
enable password 7 1xxx
aaa new-model
aaa session-id common
clock timezone CET 1 0
clock summer-time ita recurring last Sun Mar 3:00 last Sun Oct 3:00
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn FCZ1626C4KS
username xxxx privilege 15 password 7 xxxxx
redundancy
controller VDSL 0/0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.10.164 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.21.1.1 255.255.255.240
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
shutdown
interface ATM0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 070D205E5C081A101313
transport input ssh
line vty 5 15
password 7 094E4F1B0B0414070F0D
transport input ssh
scheduler allocate 20000 1000
end
thank you and good evening
24 Replies 24
balaji.bandi
VIP Community Legend VIP Community Legend
is this config from RTR ISP
add static route as per the diagram :
ip route 172.21.1.0 0.0.0.15 10.10.10.10
Also from distrib
ip route 0.0.0.0 0.0.0.0 172.21.1.1
I take all the switches in the path layer2
BB
the posted configuration is that of the router between the switch and the distributor,
the ISP router has the following static route: ip route 172.21.1.0 255.255.255.240 10.10.10.10
I take all the switches in the path layer2 --> yes cisco 2960-x
balaji.bandi
Thanks for the clarification :
i take RTR ISP IP address 10.10.10.1 (can you post the RTR ISP config also)
Question here is :
can RTR able to ping 10.10.10.1
can RTR able to ping 172.21.1.4
from Distrib you able to ping 172.21.1.1 and 10.10.10.10 ?
show ip interface brief from all devices ?
BB
this is the config the router isp:
interface GigabitEthernet0/0/0
ip address 192.168.5.29 255.255.255.252
load-interval 30
media-type rj45
speed 100
no negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
no cdp enable
interface GigabitEthernet0/0/1.1
description "Collegamento alla rete LAN
encapsulation dot1Q 1 native
ip address 10.10.10.3 255.255.255.0
standby 10 ip 10.10.10.1
standby 10 priority 230
standby 10 preempt
no cdp enable
interface GigabitEthernet0/0/1.2
description "Collegamento alla rete LAN VOIP
encapsulation dot1Q 2
ip address 172.18.10.3 255.255.255.0
standby 100 ip 172.18.10.1
standby 100 priority 230
standby 100 preempt
interface GigabitEthernet0/0/2
no ip address
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
no ip http server
ip http authentication local
ip tftp source-interface Loopback7
ip route 0.0.0.0 0.0.0.0 192.168.3.1
ip route 192.168.2.0 255.255.255.224 10.10.10.4
ip prefix-list FilterInBGPSec description Nega le p2p, le loopback 7 delle sedi remote e permette il resto
ip prefix-list FilterInBGPSec seq 10 deny 192.168.0.0/16 ge 30 le 30
ip prefix-list FilterInBGPSec seq 20 permit 7.0.255.2/32
ip prefix-list FilterInBGPSec seq 25 permit 7.62.0.0/16 le 32
ip prefix-list FilterInBGPSec seq 30 deny 7.0.0.0/8 ge 32
ip prefix-list FilterInBGPSec seq 40 permit 0.0.0.0/0 le 32
ip prefix-list MatchLoo7CPESEC description Permette la loopback 7 del CPE secondario
ip prefix-list MatchLoo7CPESEC seq 10 permit 7.23.40.15/32
ip prefix-list RedConnectedBGP description Permette la LAN, la loopback di mgmt ed eventuali altre
ip prefix-list RedConnectedBGP seq 10 permit 10.10.10.0/24
ip prefix-list RedConnectedBGP seq 20 permit 7.23.40.15/32
ip prefix-list RedConnectedBGP seq 25 permit 172.16.50.0/24
ip prefix-list RedConnectedBGP seq 30 permit 10.20.10.0/24
ip prefix-list RedConnectedBGP seq 35 permit 172.18.10.0/24
ip prefix-list RedConnectedBGP seq 50 permit 172.21.10.0/28
ip radius source-interface Loopback7
end
can RTR able to ping 10.10.10.1 --> Yes
can RTR able to ping 172.21.1.4 --> Yes
the distrib. is an end user type like a pc / notebook
show ip interface brief from all devices ? --> of which devices  ?
balaji.bandi
show ip interface brief from RTR and RTR ISP?
FROM RTR ISP are you able to ping 10.10.10.10 and 172.21.1.1 ?
if the PC are you able to ping gateway  172.21.1.1 ? if yes then most PC now a days have FW, do disable windows FW and TEST it.
You running HSRP on RTR ISP, do you any other device part of HSRP ?
BB
MHM Cisco World
VIP Mentor VIP Mentor
VIP Mentor
traceroute from dist. to ISP
share the output here
The config shown in the original post clearly shows that the router interface address is 10.10.10.164 and not 10.10.10.10.
Rick
I guess static route next hop is wrong, and we will be sure if he share traceroute
Must be
ip route 0.0.0.0 0.0.0.0 10.10.10.10
Looking at this
Must be
10.10.10.10 should be the address of the 1921 router. 10.10.10.1 is the correct next hop and is the HSRP address of the ISP router.
Rick
let wait him to share traceroute,
and you correct, static route must be toward HSRP  VIP not interface IP.
this traceroute from ISP  to Dist.:
router ISP>traceroute 172.21.1.4
Tracing the route to 172.21.1.4
VRF info: (vrf in name/id, vrf out name/id)
1 10.10.10.3   0 msec 1 msec 1 msec
2 10.10.10.10 1 msec 0 msec 1 msec
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
router ISP>
it is as if the RTR 1921 was unable to route packets to the Distr.
Georg Pauwen
VIP Master VIP Master
VIP Master
since the interface on the 1921 router has IP address 10.10.10.164, the route on the ISP router
should be 'ip route 172.21.1.0 255.255.255.240 10.10.10.164'
Iaco
Beginner
Beginner
hi all,
the interface on the RTR correct is:
ip address 10.10.10.10 255.255.255.0
duplex auto
speed auto
I need traceroute can you share results?
Recognize Your Peers
