09-25-2018 01:21 AM - edited 03-03-2019 08:54 AM
Greetings! This is a revision of a previous question.
Is there a way to use sub interfaces on the routers to somehow "trick" the switch into considering the host/ client ( at 192.168.0.1 / PC11) as a member of VLAN 10?
Just asking the weird question as I go through the study program I found on YouTube.
Solved! Go to Solution.
09-25-2018 05:25 AM
09-25-2018 05:08 PM
09-25-2018 05:25 AM
09-25-2018 08:09 AM
so my host/client at the top-right only needs to connect to the router it's connected to via crossover? I just have to create a subinterface and make the Default-gateway of the host/client the ip of whatever I assign to the sub-interface and it will act naturally the same?
09-25-2018 05:08 PM
09-29-2018 03:02 PM
IRB.. gotchya I will look into that but yes that paraphrasing is exact to my intentions! Thank you guys for being as potent as you are! Really have been amazed by this "forum".
09-25-2018 08:27 AM
