Dialler Caller screening with ISDN T/A connected to Cisco 2522
ntwrkrho
Is it possible to use "dialer caller 123456" command on a dialer interface of a cisco 2522 router with async ISDN TA modems and allow access to the network from that (123456 tel number) location only?
Thank you.
mazhar71
If you use "dialer caller" command in dialer profile , this command is used for binding the comming call to the appropriate dialer inrterface. If not macth the number then the authenticated name is used. So you can use it for your purpose.
If you use "dialer caller" command on the rotarry group , it exactly does what you want. It screens the call like "isdn caller" command and doesn't answer the call if the number is not matched. You can use it again.
But in either case you must be able to screen the number.
Thank you for your suggestions.
Here is part of the configuration that I tried out. Screening however does not work. Dialer 1 accepts any call. This is the correct way to create a rotary group is it not?
interface Serial4
physical-layer async
no ip address
encapsulation ppp
async mode interactive
dialer in-band
dialer rotary-group 1
interface Serial5
no ip address
encapsulation ppp
dialer in-band
interface Dialer1
encapsulation ppp
dialer in-band
dialer wait-for-carrier-time 60
dialer caller 0212012345
dialer caller 0212012346
dialer map ip 192.168.1.2 name USER-01
dialer map ip 192.168.1.3 name uSER-02
dialer-group 1
snapshot client 15 360 suppress-statechange-update dialer
ppp authentication chap
Thank you again
Also, Cisco 2522 is running version 11.2 IOS. Will this need be upgraded?
Thank you again
