DLSW+ Ethernet to Ethernet
0btempleton
Trying to get DLSW+ to transport Netbeui from one Ethernet segment to another. This is a lab environment so I can freely mess with the configurations. On each Ethernet network there are two PCs running Netbeui. On each network the PCs can map to shares on the other PC on their network. The PCs cannot see the PCs on the other network although the routers have all the PC's Netbios names in their DLSW reachability displays.
The routers seem to peer with no problem. No circuits appear to have ever been build between the routers. I think I am missing something simple.
Here is a cut and paste of a partial router config.
dlsw local-peer peer-id 172.17.11.5 promiscuous
dlsw bridge-group 12
process-max-time 200
interface Loopback0
ip address 172.17.11.5 255.255.255.255
interface Ethernet0
ip address 172.17.10.5 255.255.255.0
media-type 10BaseT
interface Ethernet1
ip address 192.168.246.5 255.255.255.0
media-type 10BaseT
bridge-group 12
bridge-group 12 input-lsap-list 212
access-list 212 permit 0xF0F0 0x0101
Note that I have tried it with and without the access list.
8 Replies 8
t.akin
I think the bridge-protocol is missing (ibm or ieee).
It was in the config, just not in the part that I cut and pasted.
bridge 12 protocol ieee
is it possible to show me the both configuration of the dlsw-routers?
Here are the sanitized configs for both routers.
! Last configuration change at 14:54:58 EST Tue Jan 14 2003 by templba
! NVRAM config last updated at 12:54:55 EST Tue Dec 10 2002 by templba
version 11.2
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
no service udp-small-servers
no service tcp-small-servers
hostname TST2RTR006
aaa new-model
aaa authentication login default tacacs+ line
aaa authentication login NO-TACACS line
aaa authentication enable default tacacs+ none
aaa authentication ppp default local
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxx
partition flash 2 4 4
ip subnet-zero
no ip source-route
ip telnet source-interface Loopback0
ip tftp source-interface Loopback0
ip tacacs source-interface Loopback0
no ip bootp server
no ip domain-lookup
ip domain-name piedmontng.com
ip name-server 172.16.1.20
ip name-server 172.16.1.3
clock timezone EST -5
clock summer-time EDT recurring
dlsw local-peer peer-id 172.17.11.6
dlsw remote-peer 0 tcp 172.17.11.10
interface Loopback0
ip address 172.17.11.6 255.255.255.255
interface Serial0
ip address 172.26.244.6 255.255.255.0
clockrate 250000
interface Serial1
no ip address
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
ip address 10.2.0.6 255.255.0.0
interface TokenRing0
ip address 10.1.0.6 255.255.0.0
ring-speed 16
interface TokenRing1
no ip address
shutdown
interface FastEthernet0
ip address 172.17.10.6 255.255.255.0
full-duplex
bridge-group 12
router eigrp 12
network 172.17.0.0
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
logging buffered informational
no logging console
logging trap debugging
logging source-interface Loopback0
logging history critical
logging 172.16.1.4
tacacs-server host 172.16.1.2
tacacs-server key xxxxxx
snmp-server community xxxxxx RO
snmp-server community xxxxxx RW
snmp-server location Test Lab #2 Rexford
snmp-server host 172.16.1.3 public
banner motd
****************** Warning! Warning! Warning! ************************
This system is restricted to Piedmont Natural Gas authorized users for
Business purposes. Unauthorized access is a violation of the law.
This service may be monitored for administrative and security reasons.
By proceeding, you consent to this monitoring.
alias exec b sho ip int brie
line con 0
session-timeout 60
exec-timeout 30 0
password 7 xxxxxxxxxxxxxxxx
history size 100
line aux 0
login authentication NO-TACACS
transport input all
line vty 0 4
session-timeout 60
exec-timeout 0 0
logging synchronous
history size 100
transport preferred telnet
transport input telnet
ntp clock-period 17180307
ntp source Loopback0
ntp server 172.26.250.2
ntp server 172.26.250.1 prefer
end
! Last configuration change at 14:50:24 EST Tue Jan 14 2003 by templba
version 12.1
no service single-slot-reload-enable
hostname TST2RTR010
boot system flash c2600-js56i-mz.121-5.T9.bin
logging buffered 64000 debugging
logging rate-limit console 10 except errors
no logging console
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login NO-CARE none
aaa authentication enable default group tacacs+ none
aaa authentication ppp default local group tacacs+
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxx
username test password 7 xxxxxxxxxxxxxx
username TST3RTR001 password 7 xxxxxxxxxxxxxxx
ip subnet-zero
no ip source-route
no ip finger
no ip domain-lookup
ip dhcp excluded-address 192.168.246.1 192.168.246.24
ip dhcp pool TSTLAB
network 192.168.246.0 255.255.255.0
default-router 192.168.246.13
dns-server 172.17.65.20
netbios-name-server 172.17.65.20 172.17.65.30
no ip bootp server
ip multicast-routing
isdn switch-type basic-ni
call rsvp-sync
cns event-service server
dlsw local-peer peer-id 172.17.11.10 promiscuous
interface Loopback0
ip address 172.17.11.10 255.255.255.255
interface FastEthernet0/0
ip address 192.168.246.10 255.255.255.0
ip pim sparse-dense-mode
duplex auto
speed auto
bridge-group 12
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn spid1 xxxxxxxxxxxxxxxxxxxxxxx
isdn spid2 xxxxxxxxxxxxxxxxxxxxxxx
ppp multilink
interface Serial0/0
no ip address
encapsulation frame-relay
interface Serial0/0.100 point-to-point
frame-relay class 128k-cir
frame-relay interface-dlci 100
interface Serial0/0.204 point-to-point
ip address 192.168.224.10 255.255.255.0
ip ospf network point-to-multipoint
frame-relay interface-dlci 204
interface FastEthernet0/1
ip address 172.17.10.10 255.255.255.0
duplex auto
speed auto
interface Dialer1
description Test Dial Backup from CHO
ip address 192.168.250.10 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name TST3RTR001
no cdp enable
ppp authentication chap
ppp multilink
router eigrp 12
network 172.17.0.0
network 192.168.224.0
network 192.168.250.0
no auto-summary
eigrp log-neighbor-changes
router ospf 13
log-adjacency-changes
network 192.168.224.0 0.0.0.255 area 0
ip kerberos source-interface any
ip classless
no ip http server
ip pim send-rp-announce Loopback0 scope 6
ip pim send-rp-discovery scope 6
map-class frame-relay 128k-cir
no frame-relay adaptive-shaping
map-class dialer cbdialer
dialer callback-server username
map-class dialer cb
logging 172.16.1.4
access-list 1 remark For Dialer-List 1
access-list 1 permit any
access-list 102 permit tcp any host 172.17.10.10 eq telnet
access-list 102 dynamic testlist timeout 5 permit ip any any
dialer-list 1 protocol ip list 1
snmp-server location Test Lab #2 Rexford Road
snmp-server host 172.16.1.3 xxxxxxxxx
tacacs-server key xxxxxxxxx
dial-peer cor custom
banner motd
TST2RTR101******** Warning! Warning! Warning! ************************
alias exec b show ip interface brief
line con 0
session-timeout 60
exec-timeout 30 0
history size 100
transport input pad v120 telnet rlogin udptn
line aux 0
modem InOut
transport input all
speed 115200
line vty 0 4
session-timeout 60
exec-timeout 0 0
logging synchronous
history size 100
ntp clock-period 17208753
ntp server 172.17.11.4 prefer
end
If you see your DLSW peers, it is a pretty safe bet that DLSW is functioning properly. You might want to check on the following commands... I am not a NetBios expert, but it looks like they might be affecting what the router will forward.
I have thought about those but I am only runing Netbeui and those commands appear to apply to Netbios over IP.
Thanks.
To troubleshoot your problem I recommend this page:
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_tech_note09186a008009424a.shtml
Anyway, if you think there's no problem with routers, have you tried reconfiguring your PC's ?
Netbeui = Netbios Enhanced User Interface
"Data-link switching (DLSw) provides a means of transporting IBM Systems Network Architecture (SNA) and network basic input/output system (NetBIOS traffic over an IP network. It serves as an alternative to source-route bridging (SRB), a protocol for transporting SNA and NetBIOS traffic in Token Ring environments that was widely deployed prior to the introduction of DLSw. In general, DLSw addresses some of the shortcomings of SRB for certain communication requirements---particularly in WAN implementations. "
If this is a lab environment, I would suggest taking most everything out of the config except the bare minimum. Get the config to work and then start adding back in the pieces that are required for the production environment.
The config looks good and here is a link to help you confirm it...
You may consider an explicit peer statement rather than promiscious configuration. Unless you plan on building a whole lot of these type of connections to one hub peer.
http://www.cisco.com/en/US/partner/tech/tk331/tk336/technologies_configuration_example09186a0080093ece.shtml
