I know EtherChannel load balancing can use either MAC addresses, IP addresses, or the TCP port numbers.
1 Can I config it to make sure every port under the same Channel group has the same traffic utilization?
2 If one of the Etherchannel physical port has traffic more than its physical bandwidth, why switch can't use another Etherchannel physical port to share the traffic?
