fabric enable problem...
jaejun-lee
Hi!
WS-X6248-RJ-45(Slot 1) Module does not appear in "Sh Faric Status Command".
Is it normally this? or not?
IC_2F_K_CL3MAIN_S#sh fabric status
slot channel speed module fabric
status status
2 0 20G OK OK
3 0 20G OK OK
7 0 20G OK OK
8 0 8G OK OK
IC_2F_K_CL3MAIN_S#sh mod
Mod Ports Card Type Model Serial No.
1 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD03290934
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL08424ZCL
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL08414SHZ
7 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAD083905JH
8 2 Supervisor Engine 720 (Hot) WS-SUP720-BASE SAD083900SW
Mod MAC addresses Hw Fw Sw Status
1 00d0.d39a.e698 to 00d0.d39a.e6c7 1.1 4.2(0.24)VAI 8.3(0.110)TE Ok
2 0012.005c.618c to 0012.005c.61a3 2.1 12.2(14r)S5 12.2(17d)SXB Ok
3 0012.0092.f464 to 0012.0092.f47b 2.1 12.2(14r)S5 12.2(17d)SXB Ok
7 0011.21ba.6a48 to 0011.21ba.6a4b 3.1 8.1(3) 12.2(17d)SXB Ok
8 0011.21b9.ad44 to 0011.21b9.ad47 3.1 8.1(3) 12.2(17d)SXB Ok
Mod Sub-Module Model Serial Hw Status
2 Centralized Forwarding Card WS-F6700-CFC SAL08353658 2.0 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL08321MUP 2.0 Ok
7 Policy Feature Card 3 WS-F6K-PFC3A SAD08290B6N 2.4 Ok
7 MSFC3 Daughterboard WS-SUP720 SAD083702CC 2.3 Ok
8 Policy Feature Card 3 WS-F6K-PFC3A SAD083607RM 2.4 Ok
8 MSFC3 Daughterboard WS-SUP720 SAD083801P3 2.3 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
7 Pass
8 Pass
thank you
Prashanth Krishnappa
It is normal. WS-X6248-RJ-45 is not a fabric enabled card but a classic card which has "bus" only connections. Hence, you do not see it in the output of sh fabric status.
Hope this helps.
