FW[MOD 33]: radian_monitor_pll:: port_num[12] unit[3] bcmport[5] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
Hello Everyone,
Here is my C6832-X-LE VSS switch log , I could not find anything related or any lead to this log and need help to reach the problem, I appreciate if you share your comment for this problem and on the other hand the port does not operate on both switches randomly so I could not lead to a conclusion for this problem as well.
# show version
Cisco IOS Software, c6848x Software (c6848x-ADVENTERPRISEK9-M), Version 15.4(1)SY1, RELEASE SOFTWARE (fc8)
KevinBrown
Dear Roshan,
It's related to your VSL.
I was very looking for it
You are looking for something that is not there...
:P
