GBIC Serial Numbers in 65xx chassis with Native IOS
andrew.butterworth
Rising star
Rising star
Is there any way to tell from the command line what the serial numbers are of GBIC's installed in 6516 modules in a 65xx series chassis running Native (Integrated) IOS? With a 3550 you can use the command 'show controllers ethernet-controller gigabitethernet 0/1 phy' and this will show you the Vendor Name, revision and the serial number. Is there an equivilent with a 65xx series?
Andy
Prashanth Krishnappa
sh idprom interface gigabitEthernet x/y
Thanks for that, I don't know how I missed the command. Anyway it didn't work I got a response saying 'GBIC is not security enabled'
Andy
Is there an equivalent for Catos for getting the serial numbers for gbics ?
Recognize Your Peers
