Help me choose a CIsco Broadband router
hungnm
Hi there,
Pls help me choose a Cisco Broardband router have 1 port WAN (V35) WIC,
4 Ethetnet port and have some feature:
- DHCP
- Firewal
- NAT
Thank you very much
ndoshi
Hi ,
I would recommend to go for 2600 / 3600 series router .
Nilesh
Hi Nilesh,
Because my customer office very small only 4 PC and 1 server, i think that router 2600/3600 series too large.
Could you show me smaller router ?
Thank you very much
Best regards
Hung
tepatel
The cheapest router that you can use for that is 805. which has 1 serial port and 1 eth port with all the other software features that you are looking for. You can plug a hub with that 1 eth port if you need more ports.
Pl. visit here for more on capabilities and comparision of 800 series router.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tsr/fssprocr/sftrad.htm
OR
Nest router model is 1600 serirs router. Pl. visit
http://www.cisco.com/univercd/cc/td/doc/pcat/1600.htm
Thank you very much for your support, your information very useful for me.
Best regards.
Hung
