Help with Cisco 1711
jaguarrt1978
Beginner
Beginner
I have setup my cisco router but none on the computers on the LAN are able to connect to the internet. I am able to connect to the router from outside, ping it and even port forwarding is working. Any help would be appreciated.
Config File
version 12.3
no service pad
service tcp-keepalives-in
service password-encryption
service compress-config
hostname online
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 52000 debugging
enable secret 5 ******************
username polo privilege 15 password 7 *********
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
ip dhcp pool local
network 10.0.0.0 255.0.0.0
dns-server 64.190.x.x.x.0.11
default-router 10.0.0.1
ip name-server 64.x.x.10
ip name-server 64.x.x.11
ip cef
ip ids po max-events 100
no ftp-server write-enable
interface Null0
no ip unreachables
interface FastEthernet0
description $ETH-WAN$$FW_OUTSIDE$
ip address 64.190.x.x.x.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
shutdown
interface Vlan1
description $FW_INSIDE$
ip address 10.0.0.1 255.0.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
router rip
version 2
passive-interface FastEthernet0
network 10.0.0.0
ip default-gateway 64.x.x.193
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source static tcp 10.0.0.2 22 interface FastEthernet0 22
no cdp run
control-plane
line con 0
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password 7 **************
login
transport input ssh
transport output ssh
scheduler interval 500
7 Replies 7
rais
Rising star
Rising star
Where is your access-list 1?
Thanks.
Oh! I forgot to paste that
access-list 1 permit 10.0.0.0 0.0.0.255
What kind of box is this? You refer to it as a router. But there is a VLAN interface but nothing that indicates what is connected to VLAN 1.
If you give us some more details perhaps we can do more to figure out what is happening.
Rick
Rick
Actually I have 1 linux machines and 1 windows machine connected behind this router. All the machines are configured for DHCP. The linux machine is the server 2 which there is port forwarding for SSH. Both of these machines cannot access the internet.
lloyd
Beginner
Beginner
I don't see any of the inside interfaces up? Don't you need at least one of them plugged into a switch?
All four interfaces are showing shutdown:
Try this-
switchport access vlan 1
no ip address
Did you make sure that your FastE ports all have access to the vlan you configured ?
Router(config)#interface range fastEthernet 1-4
Router(config-if-range)#switchport access vlan 1
Try that.
I did change the following the router seems to be working fine now.
Thanks to everybody for their help,
Recognize Your Peers
