Showing results forĀ
Search instead forĀ
Did you mean:Ā
how can l get into Rommon mode first
morenike1_2
Beginner
Beginner
I erased the IOS in my router 2620XM and am now receiving error messages like all sorts of funny alphabets. How can l get into rommon first  to reinstall the IOS back. This is because it is not allowing me to do anything. If l press any key on the key board all l see is just funny characters the screen. Can l get any professional help pls.
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Had you searched, you would have found may posts similar to your.
Change terminal speed until you get readable output. Then proceed from there.
paolo bevilacqua
Hall of Fame Master
Recognize Your Peers
