inter-vlan routing using IEEE 802.1q
ksonaike
I have a cisco router 2600 that I want to use for Inter-vlan routing. I entered this command at the sub-interface
router2600(config-subif)#encapsulation dot1q 1
I received this error message
% Invalid input detected at '^' marker
With this I cannot assign Ip address to the sub interface . The error message I get when I do that is
router2600(config-subif)#ip address 172.16.1.254 255.255.0.0
Configuring IP routing on a LAN subinterface is only allowed if that subinterface is already configured as part of an IEE 802.10, IEE802.1Q or ISL vLAN
My IOS is 12.2(1a)
5 Replies 5
don.wolf
Ensure that you are trying to apply this to a FastEthernet interface only. ISL is not supported on 10BaseT interfaces.
Thanks Don,
The Interface is fastethernet. My main problem is that I need to encapsulate the subinterface with dot1q which is for IEEE802.1q. but there is no encapsulation command at the interface and subinterface. If I don't encapsulate there is now way the sub interface will knew the vlan that is routing for, neither can I assign IP address to the subinterface. My ios version is 12.2(1a).
To enable the inter-vlan routing (ISL or DotQ) on C2600, you must have at least C2620 model with at least IP Plus (!) Feature set IOS istalled. IP-only version does not enable this functionality. What is your version ? (show ver, show flash). See also the Feature Navigator for Cisco IOS tool on CCO TAC (http://www.cisco.com/cgi-bin/Support/FeatureNav/FN.pl).
Jozef
I have IP Only version, with this my problem is solved thanks
spavee
Which sub-interface that you configured? So,if you encap dot1q you CANNOT configure on interface fa0/0.1.
You have to begin configure interface fa 0/0.2.
Because interface fa 0/0.1 has reserved.
Please acknowleage me?
