12-01-2005 04:13 AM - edited 03-03-2019 12:59 AM
I need help concerning interconnecting two Cisco switches (3550s) using a non-Cisco switch or hub on the LAN. I have noticed that the two Cisco switches connected using a non-Cisco switch are able to communicate well, however a PC connected to the non-Cisco switch/hub can not ping any device on the LAN. The non-Cisco device is a working one. When the two Cisco switches are connected using a Cisco switch, PCs connected to the interconnecting switch are able to ping. Whats the explanation? Please help.
12-01-2005 04:36 AM
what brand/model is the non-Cisco switch ? The problem could be related to either the way the 3550 switches are configured, or, depending on the type of non-Cisco switch, VLAN propagation is handled. Can you post the configuration of one of the 3550 switches, and, if possible, that of the non-Cisco switch ?
GP
12-02-2005 07:30 AM
Building configuration...
Current configuration : 3342 bytes
! No configuration change since last restart
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
clock timezone GMT -2
ip subnet-zero
ip rcmd rcp-enable
ip rcmd remote-username cwuser
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode dynamic desirable
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address
ip default-gateway
ip classless
ip http server
snmp-server community
snmp-server location
snmp-server system-shutdown
snmp-server enable traps snmp authentication warmstart linkdown linkup coldstart
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps flash insertion removal
snmp-server enable traps bridge
snmp-server enable traps stpx
snmp-server enable traps rtr
snmp-server enable traps port-security
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps MAC-Notification
snmp-server enable traps hsrp
snmp-server enable traps cluster
snmp-server enable traps copy-config
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
line con 0
line vty 0 4
login
line vty 5 15
login
ntp clock-period 17180064
end
12-02-2005 06:39 AM
Have you tried setting 'switchport mode access' on the ports connected with the non-Cisco equipment?
