IP PIM MULTICAST PROBLEM
a_mrk
We have enabled multicast videoconferencing in our
lan and wan.
1) The lan is segmented with vlan configuration and
L 3 Switch.
2) IP PIM is enabled in vlan 1 and vlan 16.
3) The WAN router sits in vlan 1.
4) The multicast video reaches the hosts in vlan 16
from the branches through the wan router.
5) The multicast video from the hosts in vlan 16
does not reach the hosts in branches.
6) The above problem gets rectified and everything
is fine if a host in vlan 1 joins the
conference.
7) Is is it a RPF issue ? What should be done to
solve the problem without a host from vlan 1
joining the conference.
M.Radhakrishnan
mrk@thehindu.co.in
smif101
Level 4
Level 4
Please add your configs
Thankyou Mr. Smif.
I am enclosing the reqd. conf. of the 2 L3 switches
running HSRP and the WAN ROUTER.
L3 switch 1
ip multicast-routing
spanning-tree vlan 1,10,24,40,64,200 priority 16384
interface Vlan1
description " *** Network Routers & Switches VLAN ***"
ip address 10.10.0.1 255.255.248.0
no ip redirects
ip pim sparse-dense-mode
ip cgmp
standby 1 ip 10.10.7.254
standby 1 priority 200
standby 1 preempt
interface Vlan16
ip address 10.10.23.252 255.255.248.0
ip helper-address 10.10.16.29
no ip redirects
ip cgmp
standby 3 ip 10.10.23.254
standby 3 priority 50
router eigrp 100
network 10.0.0.0
network 192.168.200.0
auto-summary
no eigrp log-neighbor-changes
ip pim rp-address 1.1.1.1 20
access-list 20 deny 224.0.1.39
access-list 20 deny 224.0.1.40
access-list 20 permit 224.0.0.0 15.255.255.255
L3 SWITCH 2
spanning-tree vlan 16,32,48,56 priority 16384
interface Vlan1
ip address 10.10.0.2 255.255.248.0
no ip redirects
ip cgmp
standby 1 priority 50
interface Vlan16
ip address 10.10.23.253 255.255.248.0
no ip redirects
ip cgmp
standby 3 priority 200
standby 3 preempt
router eigrp 100
network 10.0.0.0
auto-summary
ROUTER 1
interface loopback 0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
backup interface FastEthernet0/1
ip address 10.10.1.1 255.255.248.0
ip cgmp
interface Serial1/2
description "Connected to Bangalore"
bandwidth 2048
ip address 192.168.9.11 255.255.255.0
ip multicast rate-limit out 500
service-policy output browse
encapsulation ppp
ip route-cache flow
priority-group 2
down-when-looped
serial restart-delay 0
interface Serial1/3
description "Connected to Hyderabad"
bandwidth 2048
ip address 192.168.12.11 255.255.255.0
encapsulation ppp
ip route-cache flow
priority-group 2
down-when-looped
interface Serial2/2
description "Connected to Trivandrum"
bandwidth 2048
ip address 192.168.21.11 255.255.255.0
encapsulation ppp
ip route-cache flow
priority-group 2
down-when-looped
router eigrp 100
network 10.10.0.0 0.0.255.255
network 192.168.0.0 0.0.255.255
network 1.1.1.1 0.0.0.0
auto-summary
NOTE : THE ROUTER IS CONNECTED TO ----- SWITCH 1 ---------
REMOTE ROUTER 1
ip address 192.168.11.21 255.255.255.0
ip cgmp
interface Serial0/0
description "Connected to Chennai"
bandwidth 2048
ip address 192.168.12.12 255.255.255.0
service-policy output voice
encapsulation ppp
down-when-looped
router eigrp 100
auto-summary
Could you please attach result from each routers using "show ip mroute" command?
Just in case, Why don't you try to confiure "ip pim sparse-dense mode" command into the loopback 0 interface?
I think that the loopback 0 interface is for Rp.
Right?
Thankyou friends.
We have more or less sorted out the problem.
The problem is due to the behaviour of the multicast. TO avoid flooding the network multicast
works in co-ordination with igmp and cgmp and prunes
the multicast from entering the segments where there
are no hosts for the multicast group active.
In our case as the router sits in VLAN 1 and there are hosts active in the multicast group the other side of the router (wan side) but the lan
side of the router does not recognise it and so multicast is forwarded to VLAN 1 only when a host joins the group in VLAN 1.
But we have found a way of making the multicast forwarded to VLAN 1 by either giving the
ip igmp join-group
either in the router f0/0 or in the VLAN 1 interface of the L3 switch.
this solved our problem
thankyou for the replies.
M.Radhakrishnan mrk@thehindu.co.in
