Ip problem
kmoors
I have cisco soho router 97
with a LAN of 10 computers
I have installed a fixed configuration of ip numbers
192.168.254.1 router
These computers can surf on the internet
192.168.254.2 computer 1
192.168.254.3 computer 3
192.168.254.4 computer 4
192.168.254.5 computer 5
the router is connected to a hub with another 6 computers
192.168.254.6 computer 6
192.168.254.7 computer 7
192.168.254.8 computer 8
192.168.254.9 computer 9
192.168.254.10 computer 10
The computers that have an ip number >192.168.254.7 have problems on working on my LAN
they can acces the lan but after a while they are disconnected, if i restart my PC it runs again for a while
do you know why ?
if only one of your machines is affected, it sounds more like a problem with that particular machine. Can you try and check if the cable is connected properly, and maybe replace the network card on the affected machine ?
GP
It is not only one computer but all the computers above the Ip number 192.168.254.7 and if i change a computer that has problems with an Ip above 192.168.254.7 with for example 192.168.254.6 the problems for that computer are solved but i have 10 computers so i must go above the 192.168.254.7.
The funny thing is that it works for sometimes 10 minutes
did you check your subnet mask configuration of router and pcs? It sounds like you are using a 29 bit mask. It provides you a subnet 192.168.254.0 to 192.168.254.7, with usable addresses 192.168.254.1 to 192.168.254.6.
vellanikaran
Hai Kmoors ,
Mr.Nihal is very true
Change all the subnet mask including the router to 255.255.255.0,so that you can use the entire range 192.168.254.0.
Regards ,Alex Paul
