ISDN PRI unique problem
nbhandarkar
My problem is with an ISDN PRI. Whenever I fire an ISDN line to any remote site.....It always connects to the remote site using the 30th channel instead of taking random channel. I didn't find any prob with config.......have anyone faced this kind of problem???
The essential part of config is as below:
controller E1 1/0
framing NO-CRC4
channel-group 0 timeslots 31
channel-group 1 timeslots 1
channel-group 2 timeslots 2
channel-group 3 timeslots 3
channel-group 4 timeslots 4
channel-group 5 timeslots 5
channel-group 6 timeslots 6
channel-group 7 timeslots 7
channel-group 8 timeslots 8
channel-group 9 timeslots 9
channel-group 10 timeslots 10
channel-group 11 timeslots 11
channel-group 12 timeslots 12
channel-group 13 timeslots 13
channel-group 14 timeslots 14
channel-group 15 timeslots 15
channel-group 16 timeslots 16
channel-group 17 timeslots 17
channel-group 18 timeslots 18
channel-group 19 timeslots 19
channel-group 20 timeslots 20
channel-group 21 timeslots 21
channel-group 22 timeslots 22
channel-group 23 timeslots 23
channel-group 24 timeslots 24
channel-group 25 timeslots 25
channel-group 26 timeslots 26
channel-group 27 timeslots 27
channel-group 28 timeslots 28
channel-group 29 timeslots 29
channel-group 30 timeslots 30
interface Serial1/0:15
description "isdn pri no. is XXXX8905"
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
no cdp enable
ppp authentication chap
ppp multilink
interface Dialer11
description ISDN BACKUP
ip unnumbered Serial1/1:3
encapsulation ppp
dialer pool 1
dialer remote-name core2
dialer idle-timeout 1800
dialer string XXXXXXXX
dialer-group 1
<omitted>
dialer-list 1 protocol ip permit
thanks.
Kevin Dorrell
Level 10
Level 10
This behaviour is normal.
The convention is that the subscriber starts at the top of the range, i.e. channel 30, and works downwards. For outgoing calls it will always use the highest available channel number.
The exchange, on the other hand, starts at the lowest channel, and works upwards. It always takes the lowest available channel number. You will always see the incoming calls on low channel numbers,
That way, the probability of a call collision is reduced to the absolute minium, and then can only happen on the last available channel.
X.25 normally works in the same way: DTE starts at the top channel, and DCE starts at the bottom.
Why do you feel this is a problem? There must be a clue in the way you have tried to pin down the channel groups. Normally you let all the channels in a single pool, and the dialer uses whichever on it wants. For outgoing calls it just picks a channel, starting at 30, and uses it. For incoming calls, the channel gets bound to the dialer by the CHAP remote name.
That leaves us with the command I don't understand, the ip unnumbered Serial1/1:3. What are you trying to achieve there? Is S1/1 a fractional E1 or something?
Kevin Dorrell
Luxembourg
Kevin,
How do you do this BOLD typing... ???
UNDERLINED ????
ITALIC ???
Thank you
Marinos
