Layer 3 Switch, Packet tracer, Help
crazo_123
Hello =)
I am new to networking and im having trouble configuring my layer 3 switch.
I have done some research and have tried several different ways to configure the multi layer switch to produce DHCP for each VLAN.
Each VLAN must have a different subnet.
Any help would be much appreciated
Thank you <3
6 Replies 6
Sandesh Sawant
Yes, you need to have different subnet for each vlan.
Let us consider you are having 3 vlans 10, 20 and 30.
Vlan 10 : 192.168.10.0/24
Vlan 20 : 192.168.20.0/24
Vlan 30 : 192.168.30.0/24
This switch interface vlan is the default gateway for the respective hosts in respective vlans.
Configuration :
Configure vlan 10, 20 and 30.
interface Vlan10
 ip address 192.168.10.1 255.255.255.0
 no shut
interface Vlan20
 ip address 192.168.20.1 255.255.255.0
 no shut
interface Vlan30
 ip address 192.168.30.1 255.255.255.0
 no shut
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp excluded-address 192.168.30.1 192.168.30.10
ip dhcp pool vlan10
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   lease infinite
ip dhcp pool vlan20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   lease infinite
ip dhcp pool vlan30
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
   lease infinite
There are multiple options in DHCP configuration.
Configure as per your requirement.
e.g.
Cisco-switch(config)#ip dhcp pool vlan10
Cisco-switch(dhcp-config)#?
DHCP pool configuration commands:
  accounting           Send Accounting Start/Stop messages
  address              Configure a reserved address
  bootfile             Boot file name
  class                Specify a DHCP class
  client-identifier    Client identifier
  client-name          Client name
  default-router       Default routers
  dns-server           DNS servers
  domain-name          Domain name
  exit                 Exit from DHCP pool configuration mode
  hardware-address     Client hardware address
  host                 Client IP address and mask
  import               Programatically importing DHCP option parameters
  lease                Address lease time
  netbios-name-server  NetBIOS (WINS) name servers
  netbios-node-type    NetBIOS node type
  network              Network number and mask
  next-server          Next server in boot process
  no                   Negate a command or set its defaults
  option               Raw DHCP options
  origin               Configure the origin of the pool
  relay                Function as a DHCP relay
  remember             Remember released bindings
  renew                Configure renewal policy
  reserved-only        Only allocate reserved addresses
  server               Configure the server ID option value
  subnet               Subnet allocation commands
  update               Dynamic updates
  utilization          Configure various utilization parameters
  vrf                  Associate this pool with a VRF
To check if its working fine please use command below,
Cisco-switch#show  ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/             Lease expiration        Type
            Hardware address/
            User name
Also refer the links below,
https://supportforums.cisco.com/discussion/10791041/how-configure-cisco-switch-3750-dhcp-2-vlan
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_52_se/configuration/guide/3750scg/swipaddr.html#wp1094520
Hope this helps.
Sandesh Sawant.
<rate if useful >
Thanks so much for the help =D was very useful =D
Hi Crazo,
Thanks for the reply and the rating.
With best regards,
Sandesh Sawant.
LJ Gabrillo
Level 5
Level 5
Well the reason your DHCP is not working is because you do not have an equivalent LAYER3 interface for that VLAN
You only have one L3 VLAN w/c is VLAN300
To make your DHCP work make sure to create L3 interfaces for all the networks you have in your L3 switch.
#interface vlan 10
  #ip address <IP> <SM>
#interface vlan 11
#interface vlan 12
vice versa
Hey dude don't forget to mark as correct and as well rate posts that have been helpful to you :)
It closes your discussion and as well give supportforums an archive of this :D
