Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I would consider the "best" way to balance egress traffic would be using PfR, this assuming your equipment supports it.
From what you describe, 2nd best (for a single edge device) would be to direct all traffic to it (single default route to it) and allow it to use BGP ECMP. The latter requires BGP routing be configured to support two paths, maximum-paths 2, and usage of the hidden command bgp bestpath as-path multipath-relax.
