making NM-16ESW in 2611XM work ?
p.devalck
I recently had to configure abovementioned router with Ethernet switch network module.
However, I do not seem te be able to route from a port (1/0 - 1/15) on the NM-16ESW module to the router ports (0/0 and 0/1).
Software is IP BASE 12.3 (5b)
I'm trying to connect local users to the NM-16ESW module (several ports per VLAN) and then perform both inter-VLAN routing and routing to the in-built router ports.
I did so by declaring the ports as "switchport mode access" and "switchport access vlan NNN" and then defining "interface vlan NNN" with "ip address XXX Mask". Can anyone declare what is wrong ? The command formats used are similar as for C3550 L3 switches.
Another attempt involved declaring a port on the NM-16ESW as a trunk port. "switchport mode trunk", "switchport encapsulation dot1q", "switchport trunk allowed vlan NNN" for several values.
When doing "show run" afterwards, the trunk characteristics had all disappeared.
As it is the first time that I try to configure ports on such a module, I am not sure whether I'm using the correct commands, or that the software is supporting these features.
Can anybody clarify ?
Thank you
Paul De Valck
ivillegas
Level 6
Level 6
I too am going to have the configuration that was specified in this question. Although the document you specified has all the questions, I am very new at this and need to route between networks I create on the switch. Do you have a example of the code to accomplish this?
thank you
You can find a configuration underneath,
but this is only the result of the show run command.
For this to work there are first the commands to define the VLANs :
....#vlan database
....(...)#vlan NN name ....
these commands are necessary. Without defining the vlans, it is not possible to route from the switch-ports.
However, these commands do not show up in a "show run"
Hope this helps a little.
interface FastEthernet0/0
description To_firewall_naar_DvS
ip address 192.168.0.125 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description naar WLAN_apparatuur_via_SDH
no ip address
speed 10
full-duplex
interface FastEthernet0/1.701
encapsulation dot1Q 701
ip address 172.28.1.2 255.255.255.252
ip access-group 21 out
interface FastEthernet0/1.801
encapsulation dot1Q 801
ip address 172.28.1.6 255.255.255.252
interface FastEthernet1/0
description naar LAN DvS voor vast aangesloten apparatuur sluizen
switchport access vlan 10
no ip address
interface FastEthernet1/1
description naar vast aangesloten apparatuur sluizen
no ip address
interface FastEthernet1/2
switchport access vlan 2
no ip address
interface FastEthernet1/3
switchport access vlan 3
no ip address
interface FastEthernet1/4
no ip address
shutdown
interface FastEthernet1/5
no ip address
shutdown
interface FastEthernet1/6
no ip address
shutdown
interface FastEthernet1/7
no ip address
shutdown
interface FastEthernet1/8
no ip address
shutdown
interface FastEthernet1/9
no ip address
shutdown
interface FastEthernet1/10
no ip address
shutdown
interface FastEthernet1/11
no ip address
shutdown
interface FastEthernet1/12
no ip address
shutdown
interface FastEthernet1/13
no ip address
shutdown
interface FastEthernet1/14
description naar_WLAN_access_point_DvS
no ip address
interface FastEthernet1/15
description naar_WLAN_sluizen_via_SDH
no ip address
interface Vlan1
description Beheer_WLAN_Access_Points
ip address 192.168.0.30 255.255.255.224
ip access-group 1 out
interface Vlan2
description DvSBedrijf_via_WLAN
ip address 192.168.0.254 255.255.255.128
ip access-group 2 out
interface Vlan3
description DvSPrive_via_WLAN
ip address 192.168.0.62 255.255.255.224
ip access-group 3 out
no ip http server
ip classless
access-list 1 remark to Access Points
access-list 1 remark from network management
access-list 1 permit 10.32.1.32 0.0.0.31
access-list 1 permit 10.192.1.32 0.0.0.31
access-list 2 permit 192.168.0.126
access-list 2 remark to Workgroup Bridges & DvSBedrijf
access-list 2 remark from network management and firewall Hasselt DvS
access-list 2 permit 10.32.1.32 0.0.0.31
access-list 2 permit 10.192.1.32 0.0.0.31
access-list 3 remark to DvSPrive
access-list 3 remark from firewall Hasselt DvS
access-list 3 permit 192.168.0.126
access-list 11 remark to Access Points
access-list 11 remark from network management
access-list 11 permit 10.32.1.32 0.0.0.31
access-list 11 permit 10.192.1.32 0.0.0.31
access-list 21 permit 192.168.0.126
access-list 21 permit 172.28.1.2
access-list 21 permit 172.28.1.6
access-list 21 permit 192.168.0.136
access-list 21 permit 192.168.0.141
access-list 21 permit 192.168.0.131
access-list 21 permit 192.168.0.132
access-list 21 permit 192.168.0.133
access-list 21 permit 192.168.0.134
access-list 21 permit 192.168.0.135
access-list 21 remark to management
access-list 21 permit 192.168.0.0 0.0.0.31
