MRTG Traffic more than 110Mb
preddyi
Level 3
Level 3
I am running MRTG for monitoring graph utilization
of my network devices.
When my router gig port traffic goes more than 110Mb.
Mrtg shows cutoff or does not show any traffic.
Has anybody came acrross this problem?
Is there a remidy for the same?
Thanks in advance.
smebbin
On your router interfaces you are monitoring do the "Bandwidth 1000000" command in interface config mode. Then rewalk snmp in MRTG. This should adjust your graphs accordingly.
Brandon
This is already there.
My problem was when I create config file, and corresponding html file, MRTG shows Maximum BW as 1Gb(125MB),
but the actual traffic graph never used to exceed more than 110Mb.There it used to get cutoff.
The problem got resolved now, after creating the configuration file with SNMP version:2
Default it taked SNMP Version:1
While creating config file, I have used
" --snmp-options=:::::2 "
perl cfgmaker --snmp-options=:::::2 community@device
