MSFC3 with Hybrid Sup720 in rommon
jraarons
Can you help me find a boot helper image for the msfc3? I can't find one on Cisco website?
Seems I've had issues trying to Xmodem the large full images.
Does the MSFC3 even have a boot helper image?
Prashanth Krishnappa
The MSFC3 does not have a boot image. If you have a compact flash card, try booting from it.
Alternatively, convert the Sup720 to Native IOS, tftp the Hybrid MSFC3 image to the bootflash of MSFC3 and CAT OS to the bootflash of Sup720 and convert back.
glen.grant
Do a dir bootflash: and see if the image is there , or try dir slot0: or disk0: to see if the image is there then issue a boot statement to get it to load , like boot bootflash:imagename.
You cannot read the contents of disk0: from MSFC3 ROMMON in hybrid mode but can boot from it.
