Need help on CAR
pham_at
I have a router cisco 2600 to connect to internet.
Because I only have 128 Kbps for internet access so I want to controll bandwidth for users on the LAN for example, user1 - 64 kbps, user 2 -24 kbps ...). Following is summary about my router configuration:
ip cef
interface Ethernet0/0
ip address 192.168.10.1 255.255.255.0
rate-limit input access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 12 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 11 24000 8000 8000 conform-action transmit exceed-action drop
access-list 11 permit 192.168.10.11
access-list 11 permit 192.168.10.12
access-list 12 permit 192.168.10.111
Butwhen I do the test, users can download above the speed I have setup for them !!!
Please help me to fix this problem !!! If CAR can not resolve this problem, pls give me another solution !!!
ssymonds
Hello Mat,
the problem is most likely due to the fact that you are using a standard-access-list 1-99 i.e this checks the 'source' ip address, therefore when transmitting out of the e0/0 interface, the source addresses specified in the access-list 12 would not satisfy the car statement, as the source address would not match.
Instead, configure extended access-lists to match your traffic
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt2/1rip.htm#xtocid217152
i.e for traffic to and from host 192.168.10.111 :
ip cef
rate-limit input access-group 100 64000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 101 64000 8000 8000 conform-action transmit exceed-action drop
access-list 100 permit ip host 192.168.10.111 any
access-list 101 permit ip any host 192.168.10.111
Then check traffic to-from this host.
Please let us know results.
rgds
stvee
pham_at
It have fixed my problem.
Thanks a lot
