NM-32A card power consumption?
konjo123321
Could anyone please tell me what is the NM-32A card power consumption?
I can't find this info anywhere.
Thanks in advance
BR.
Edwin Summers
Level 3
Level 3
I'm looking into this to see if I can find it.  Power figures for some cards like this can be more difficult to find.  Do you have access to the Partner Help support where you can ask for this info?
Out of curiosity, how precise is your requirement for this information?  Are you on an extremely constricted power budget?  If your requirement is not extremely precise, it may be easier to calculate an estimate based on the maximum/typical power draw value for the platform into which the card is being installed.
Unfortunately I don't have access to such support.
I need this info for work. Before installation of any card we have to check its power consumption, etc. And what I've realised it's very hard to find any information about this NM-32A card as it's End of Life now
So if anyone have such data, please share.
