04-06-2023 02:31 AM
Hey I have been using exanic x25 and was trying to receive packets and send packets from port1. But saw that even though we are sending packets from the host side, the exanic is not able to receive anything.
I even tried the existing native_nic_example by enabling both the ports in config.tcl and creating 2 instance for native_nic_32b (one for each port ) but after building the firmware saw that even with this, i was not able to do telnet using the port 0 or port 1 (telnet through both the ports happens successfully using the default firmware given by exanic).
Is there any other config that needs to be set to receive data from the host
Thanks in advance
04-17-2023 12:49 PM
Could you verify duplex configuration and also is their any encapsulation configured, if yes then both side it should be the same.
04-17-2023 09:41 PM
Hey thanks a lot for the reply.
I am very new to exanic so not sure what you mean by duplex configuration or encapsulation configured, could you elaborate a little more and also let me know where these configuration have to be checked or changed.
Thank you in advance...
