03-06-2003 01:36 PM - edited 03-02-2019 05:39 AM
I am trying to get OSPF working between my 2 Ascend MAX6000's and my 7206. Does anyone have any tips on how to make this work?
Mitchel
03-06-2003 07:12 PM
Mitchel,
Other than making sure your interface MTU's /ospf network-type is set the same I can think of only gathering "debug ip ospf adj" from your cisco router which might show us what is keeping your router and Ascend box from going into a full state (if this is even the issue). If you can shed somemore light on your specific issue with OSPF between the two it might help us help you.
Hope this helps you,
Don
03-07-2003 09:33 AM
Don, here is output from my router and the config on the Ascend MAX. A sh ip ospf neigbor shows none.I have all interfaces except fasteht set to passive. The MAX's are connected to the fasteth int via switch.
c7206#sh ip ospf 201
Routing Process "ospf 201" with ID 216.88.192.246
Supports only single TOS(TOS0) routes
Supports opaque LSA
It is an autonomous system boundary router
Redistributing External Routes from,
static, includes subnets in redistribution
SPF schedule delay 5 secs, Hold time between two SPFs 10 secs
Minimum LSA interval 5 secs. Minimum LSA arrival 1 secs
Number of external LSA 6. Checksum Sum 0x2F659
Number of opaque AS LSA 0. Checksum Sum 0x0
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
External flood list length 0
Area BACKBONE(0) (Inactive)
Number of interfaces in this area is 630
Area has no authentication
SPF algorithm executed 156 times
Area ranges are
Number of LSA 1. Checksum Sum 0x8DD5
Number of opaque link LSA 0. Checksum Sum 0x0
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
c7206#sh ip ospf interface
FastEthernet0/0 is up, line protocol is up
Internet Address 64.240.109.1/24, Area 0
Process ID 201, Router ID 216.88.192.246, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 10
Designated Router (ID) 216.88.192.246, Interface address 64.240.109.1
No backup designated router on this network
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:07
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 2, maximum is 21
Last flood scan time is 0 msec, maximum is 4 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
c7206#sh ip ospf database
OSPF Router with ID (216.88.192.246) (Process ID 201)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
216.88.192.246 216.88.192.246 719 0x80001257 0x8DD5 21
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
206.129.12.0 216.88.192.246 719 0x80000966 0x7973 0
206.129.13.0 216.88.192.246 719 0x80000966 0x6E7D 0
207.149.12.0 216.88.192.246 719 0x8000085C 0x9250 0
207.149.12.8 216.88.192.246 1741 0x8000004E 0x7854 0
209.102.32.0 216.88.192.246 719 0x8000060E 0x8B19 0
209.102.32.128 216.88.192.246 719 0x8000060E 0x78AC 0
interface FastEthernet0/0
ip address 206.129.32.1 255.255.255.0 secondary
ip address 206.129.12.1 255.255.255.240 secondary
ip address 206.129.12.17 255.255.255.248 secondary
ip address 206.129.12.33 255.255.255.224 secondary
ip address 206.129.12.65 255.255.255.224 secondary
ip address 209.102.33.1 255.255.255.0 secondary
ip address 209.129.13.1 255.255.255.0 secondary
ip address 206.129.12.193 255.255.255.192 secondary
ip address 64.240.108.1 255.255.255.0 secondary
ip address 64.240.109.1 255.255.255.0
ip route-cache flow
ip ospf network broadcast
ip ospf priority 10
half-duplex
Hardware is DEC21140A, address is 0003.e454.2000 (bia 0003.e454.2000)
Internet address is 64.240.109.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 4/255
Keepalive set (10 sec)
Half-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 11w3d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 262 drops
5 minute input rate 1935000 bits/sec, 390 packets/sec
5 minute output rate 923000 bits/sec, 331 packets/sec
3059104494 packets input, 3087473237 bytes
Received 8523693 broadcasts, 0 runts, 3 giants, 266 throttles
2527 input errors, 2526 CRC, 0 frame, 11 overrun, 69 ignored
0 watchdog
1239 input packets with dribble condition detected
2098148658 packets output, 3472816349 bytes, 1129 underruns
1351 output errors, 131650836 collisions, 26 interface resets
0 babbles, 0 late collision, 29 deferred
222 lost carrier, 0 no carrier
MAX OSPF COnfig:
RunOSPF=Yes
Area=0.0.0.0
AreaType=Normal
HelloInterval=10
DeadInterval=40
Priority=5
AuthType=None
AuthKEy=N/A
KeyId=N/A
MD5Key=N/A
Cost=1
ASE-type=N/A
ASE-Tag=N/A
TransitDelay=1
RetransmitInterval=5
OSPF Global Options:
Enable ASBR=Yes
MAX # LSA=0
Thanks ,
Mitchel
