01-05-2018 01:43 AM - edited 03-03-2019 08:42 AM
Hi there,
I would like to ask you about something really strange on my router c4431. IOS is 3.13.04.S, MD, not deferred.
I have multiple PAT configured as example, with pool of two public address
ip nat pool NAT_10 xxx.32 xxx.33 netmask 255.255.255.240
And now the issue:
sh ip nat translations filter map-id dynamic 10
Pro Inside global Inside local Outside local Outside global
--- xxx.33 192.168.60.5 --- ---
udp xxx.32:59905 192.168.60.76:61594 yyy:40026 yyy:40026
udp xxx.33:58282 192.168.60.5:58282 zzz:443 zzz:443
That means, the PC 192.168.60.5 is accesible from the internet over any port, show command shows the first row as STATIC NAT 1:1(in show command for dynamic), but there are just only PATs in config! Interesting is, there are several rows with same inside local address as you can see in row 3. And of course, there are about 50 thousand of other rows and everything is working properly in first view.
I can do "clear ip nat translation" with forced key word and the line will be deleted, but next day or week problem occur again with different local address.
But this problem is really dangerous and security risk. Its hard to find right key words about it and find solution. Any Idea? Thanks!
01-05-2018 03:25 AM
Hello
Not sure i understand what you are querying here - Can you post the config of the router ( if applicable) as it would probably provide a much clearer understanding of your current NAT setup
res
Paul
01-05-2018 03:56 AM
Hello Paul,
there is configuration
ip nat inside source list NAT_10 pool NAT_10 overload
ip access-list standard NAT_10
permit 192.168.60.0 0.0.0.255
You can see, it is dynamic NAT/PAT. But it sometimes behaves as a static NAT as I mentioned above.
01-05-2018 05:15 AM - edited 01-05-2018 05:16 AM
Hello
Still not sure what you mean by behaving like static nat -Your have nat overload enabled with multiple public address in your nat pool and as such my understanding is that NAT will round robin between those two pubic ip address
This would be applicable as and when an inside hosts has not initiated a outside connection for a while so now that public ip will be available to be used via another inside host.
res
Paul
01-05-2018 06:46 AM
>Your have nat overload enabled with multiple public address in your nat pool and as such my >understanding is that NAT will round robin >between those two pubic ip address
true, I agree, there should be a some kind of round robin between two public address. But look again at the show command, there is line that looks exactly the same as line corresponding static NAT. This is real commnand from running router and you can see>
And I can confirm, that due to this line is computer on inside side accessible from outside, that was tested.
Has somebody seen this kind of bug ?
01-06-2018 01:01 AM - edited 01-06-2018 03:01 AM
Hello
Ha yes I understand now what you are querying, Apologies just couldn't see it!
Yes it does seem strange what’s looks like a static NAT ghost entry - Are you able:
1) reload the router
or
2) change to NVI nat
Option 2 - you should be able to transition without dropping any traffic
ip nat source list NAT_10 pool NAT_10 overload
int x/x
description WAN
ip nat enable
no ip nat outside
int x/x
description LAN
ip nat enable
no ip nat inside
No ip nat inside source list NAT_10 pool NAT_10 overload
sh ip nat nvi translations
res
Paul
