Police Does not work on Cat3550
kfarrington
Level 3
Level 3
Can anyone tell me why this configuration does not work?
All I am trying to do is rate-limit traffic on a port (any traffic)
I can do it using storm control, but i dont want to use this as it has drawbacks.
mls qos
class-map match-all port13
match any
policy-map POLICE
class port13
police 35000000 8000 exceed-action drop
interface FastEthernet0/13
switchport access vlan 21
no ip address
load-interval 30
service-policy history
service-policy input POLICE
Cat1_3550#sh policy-map int fa0/13
service-policy input: POLICE
class-map: port13 (match-all)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
match: any qm_police_inform_feature: CLASS_SHOW
class-map: class-default (match-any)
0 packets, 0 bytes
match: any
0 packets, 0 bytes
30 second rate 0 bps
Cat1_3550#
many thx indeed,
Ken
6 Replies 6
danhut
Ken,
Your class-map has to specify whether the switch should match IP or non-IP traffic. So presuming you want to police IP traffic you would do something like:
match access-group name All-IP
ip access-list standard All-IP
permit any
If it is non-IP traffic you would use a MAC access-list instead.
If you want to match both IP and non-IP then you would define a class-map for each; and then use the same aggregate policer within each class in the policy map eg.
mls qos aggregate-policer All-35Meg 35000000 8000 exceed-action drop
policy-map 123
class-map IP
police aggregate All-35Meg
class-map non-IP
Here is my simple config, it simple does not work?
mls qos
class-map match-all port13-ip
match access-group name all-ip
policy-map POLICE
class port13-ip
police 3496000 80000 exceed-action drop
interface FastEthernet0/7
no ip address
load-interval 30
ip access-list standard all-ip
permit any
Now I start a 5 meg stream from a laptop (have now moved the port onto a different switch just to make sure its not the switch)
Cat2_3550#sh int fa 0/7
FastEthernet0/7 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000c.858f.0087 (bia 000c.858f.0087)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 13/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
30 second input rate 5164000 bits/sec, 494 packets/sec
30 second ouxtput rate 0 bits/sec, 0 packets/sec
226764 packets input, 292030334 bytes, 0 no buffer
Received 304 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 20 multicast, 0 pause input
1331 packets output, 100425 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Cat2_3550#
Bizarre?
Also, below is the version of IOS.
The reason I am so stressed about this is my lab date is next week, and know my luck, i will get asked this BUT i will NOT use it unless I can get it working?
PLEASE COULD ANYONE ELSE WHO HAS TRIED AND DOCUMENTED THIS, PLEASE POST THEIR RESULTS. PPPPLEASE!!!!!!
Cat2_3550# sh hard
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Mar-03 23:42 by yenanh
Image text-base: 0x00003000, data-base: 0x007C34B0
ROM: Bootstrap program is C3550 boot loader
Cat2_3550 uptime is 59 minutes
System image file is "flash:c3550-i5q3l2-mz.121-13.EA1a.bin"
cisco WS-C3550-24 (PowerPC) processor (revision H0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0714X0H9
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0C:85:8F:00:80
Motherboard assembly number: 73-5700-10
Power supply part number: 34-0966-02
Motherboard serial number: CAT071302WE
Power supply serial number: LIT0704001M
Model revision number: H0
Motherboard revision number: A0
Model number: WS-C3550-24-SMI
System serial number: CAT0714X0H9
Configuration register is 0x10F
Cat2_3550#
it's clear from your config that the class-map is not matching traffic. As the policy-map is attached to a switch port, have you tried basing the class map on mac-address ACL or COS bit ?
No expert here, but isnt there a numeric parameter missing. Doc doesn't indicate that its optional
police bps burst-normal burst-max
looks like the police statement isnt being used. I get this showing the polce parameters
r4#sh policy-map int e0
Ethernet0
Service-policy input: test2
Class-map: test (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 1
police:
8000 bps, 1000 limit, 1000 extended limit
conformed 0 packets, 0 bytes; action: transmit
exceeded 0 packets, 0 bytes; action: drop
conformed 0 bps, exceed 0 bps violate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
it was on a cat3550 and just check, the max burst is on a router, but not a switch.
i am getting so confused, :)
