Port ACL Limitation Reasoning
UncleJP
I ran across this bit of material while learning about port access control lists:
PACLs have a few restrictions that vary from platform to platform. The following
are some of the most common restrictions:
• PACLs only support filtering incoming traffic on an interface (no outbound
filtering support).
• PACLs cannot filter Layer 2 control packets, such as CDP, VTP, DTP, PAgP,
UDLD, and STP.
• PACLs are supported only in hardware.
• PACLs do not support ACLs to filter IPv6, ARP, or Multiprotocol Label
Switching (MPLS) traffic.
1. Why don't PACLs support outbound filtering?
2. Why can't PACLs filter layer 2 control packets?
3. Why are PACLs only supported in hardware?
4. Why can't PACLs filter IPv6, ARP, or Multiprotocol Label
Switching (MPLS) traffic?
This post is loaded with questions. I greatly appreciate any input that you offer.
Jason
omz
The port ACL feature is supported only in hardware port ACLs are not applied to any packets routed in software.
TCAM is used to create an entry when port ACL is used.
There is no hardware support for output PACLs.
I appreciate the answer, omz.
