Problem with 2950
pham_at
I have a catalyst 2950. I Created 3 VLAN 1,2,3 and F0/24 port as a trunk port. I Connected this port to a server but only user on VLAN 1 can access to server.
Pls help me to solve this problem .
Thanks in advanced
6 Replies 6
milan.kulik
Level 10
Level 10
Have you configured the server NIC to support 802.1q encapsulation?
If not, the only native VLAN (VLAN1 default) users will communicate with the server.
HTH,
Milan
But, How to configure it if I use Windows NT/ 2000 with 3C905 Network Card ?
3c905 NIC can't support 802.1q encapsulation
What NIC supported 802.1q encapsulation I can used ?
Pls recommend me
Waht about the Intel E100B NIC. I believe this will
support 802.1q!
But how to configure
