03-04-2023 09:59 PM
Is there any way to confirm rated power consumption for cisco network equipment? I’ve found other type of power consumption like max and typical. Unfortunately I can NOT find rated power consumption.
Let me explain the background. NTT, one of the biggest network carrier in Japan, started evaluating equipment by Internal carbon pricing. They demand rated power consumption for calculating CO2 emission costs.
https://group.ntt/en/procurement/supplier/icp.html
Solved! Go to Solution.
03-05-2023 12:07 AM
very interesting subject. I did a quite extensive search but could not find anything similar specifically for Cisco products. I do know that Cisco is working towards the goal of achieving zero carbon emission, so maybe they come up with something similar in the future...
03-05-2023 12:07 AM
03-06-2023 08:03 AM
Thanks for your comment.
You kindly did extensive search but there is no information about rated power consumption of cisco equipment. I gueess rated power consumption is not popular except for Japan as spec information for IT infrastructure. Is it right?
If so, using rated power consumption as parameter is not reasonable...
