05-19-2003 11:02 PM - edited 03-02-2019 07:28 AM
i have a problem with redundance between 2 Cat. 3550(EMI).
Below you can see my Configs:
Catalyst1 (Master)
vtp domain XXXX_VLANS
vtp mode transparent
vlan 1
tb-vlan1 1002
tb-vlan2 1003
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 7
vlan 8
vlan 98
vlan 99
vlan 1002
tb-vlan1 1
tb-vlan2 1003
vlan 1003
tb-vlan1 1
tb-vlan2 1002
vlan 1004
bridge 1
stp type ibm
cluster enable catalyst_cluster 0
spanning-tree vlan 1 priority 24576
spanning-tree vlan 2 priority 24576
spanning-tree vlan 2 hello-time 1
spanning-tree vlan 2 forward-time 7
spanning-tree vlan 2 max-age 10
spanning-tree vlan 3 priority 20480
spanning-tree vlan 4 priority 28672
spanning-tree vlan 4 hello-time 1
spanning-tree vlan 4 forward-time 7
spanning-tree vlan 4 max-age 10
spanning-tree vlan 5 priority 28672
spanning-tree vlan 5 hello-time 1
spanning-tree vlan 5 forward-time 7
spanning-tree vlan 5 max-age 10
spanning-tree vlan 6 priority 24576
spanning-tree vlan 6 hello-time 1
spanning-tree vlan 6 forward-time 7
spanning-tree vlan 6 max-age 10
spanning-tree vlan 7 priority 24576
spanning-tree vlan 7 hello-time 1
spanning-tree vlan 7 forward-time 7
spanning-tree vlan 7 max-age 10
spanning-tree vlan 8 priority 28672
spanning-tree vlan 8 hello-time 1
spanning-tree vlan 8 forward-time 7
spanning-tree vlan 8 max-age 10
spanning-tree vlan 99 priority 24576
interface Port-channel1
switchport access vlan 3
no ip address
interface FastEthernet0/2
switchport access vlan 2
no ip address
no cdp enable
interface FastEthernet0/3
no ip address
no cdp enable
interface FastEthernet0/4
no ip address
no cdp enable
spanning-tree portfast
interface FastEthernet0/5
no ip address
no cdp enable
interface FastEthernet0/48
switchport access vlan 6
no ip address
no cdp enable
interface GigabitEthernet0/1
description Uplink to Catalyst2
switchport mode trunk
no ip address
no cdp enable
interface GigabitEthernet0/2
description Gigabit to 3Com-Switch
no ip address
no cdp enable
interface Vlan1
no ip address
no ip route-cache cef
shutdown
interface Vlan2
description xxxxxxxxxxxxxxxxx
ip address ..
no ip redirects
standby 2 ip xxx.xxx.xxx.xxx
standby 2 priority 105
standby 2 preempt
interface Vlan4
description
ip address ..
no ip redirects
standby 4 ip xxx.xxx.xxx.xxx
standby 4 priority 100
standby 4 preempt
interface Vlan5
description AL-Netz Zentrale
ip address ..
no ip redirects
standby 5 ip xxx.xxx.xxx.xxx
standby 5 priority 100
standby 5 preempt
interface Vlan6
description ALIS Pc-Netz
ip address ..
no ip redirects
standby 6 ip xxx.xxx.xxx.xxx
standby 6 priority 105
standby 6 preempt
interface Vlan7
description Transfernetz zwischen Router 3640 und Catalyst
ip address ..
no ip redirects
standby 7 ip xxx.xxx.xxx.xxx
standby 7 priority 105
standby 7 preempt
interface Vlan8
description AL-Netz mit Verbindung zum BT-Router
ip address ..
ip access-group 110 in
no ip redirects
standby 8 ip xxx.xxx.xxx.xxx
standby 8 priority 100
standby 8 preempt
interface Vlan98
description Testnet
ip address ..
no ip redirects
standby 98 ip xxx.xxx.xxx.xxx
standby 98 timers 4 20
standby 98 priority 105
standby 98 preempt
standby 98 track FastEthernet0/43 50
interface Vlan99
description TESTNETZ
ip address ..
no ip redirects
standby 255 ip xxx.xxx.xxx.xxx
standby 255 priority 105
standby 255 preempt
Catalyst2 (Backup)
vlan 1
tb-vlan1 1002
tb-vlan2 1003
vlan 2
vlan 3
vlan 4
vlan 5
vlan 6
vlan 7
vlan 8
vlan 98
vlan 99
vlan 1002
tb-vlan1 1
tb-vlan2 1003
vlan 1003
tb-vlan1 1
tb-vlan2 1002
vlan 1004
bridge 1
stp type ibm
spanning-tree vlan 1 priority 28672
spanning-tree vlan 2 priority 28672
spanning-tree vlan 3 priority 28672
spanning-tree vlan 4 priority 24576
spanning-tree vlan 5 priority 24576
spanning-tree vlan 6 priority 28672
spanning-tree vlan 7 priority 28672
spanning-tree vlan 8 priority 24576
spanning-tree vlan 99 priority 28672
no ip address
interface FastEthernet0/1
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
description Uplink to Catalyst1
no ip address
no cdp enable
no ip address
no cdp enable
interface Vlan1
no ip address
shutdown
interface Vlan2
description
ip address ..
no ip redirects
standby 2 priority 100
standby 2 preempt
interface Vlan4
description
ip address ..
no ip redirects
standby 4 priority 105
standby 4 preempt
interface Vlan5
description
ip address ..
no ip redirects
standby 5 ip xxx.xxx.xxx.xxx1
standby 5 priority 105
standby 5 preempt
interface Vlan6
description
ip address ..
no ip redirects
standby 6 priority 100
standby 6 preempt
interface Vlan7
description
ip address ..
no ip redirects
standby 7 priority 100
standby 7 preempt
interface Vlan8
description
ip address ..
no ip redirects
standby 8 priority 105
standby 8 preempt
interface Vlan98
description
ip address ..
no ip redirects
standby 98 priority 110
standby 98 preempt
interface Vlan99
description
ip address ..
no ip redirects
standby 255 priority 100
standby 255 preempt
The Catalyst 1 works fine without the Catalyst 2.
If I start the Catalyst 2 and connect both catalyst together over
the Gigabit-Port, i recive Messages below:
3w2d: STP: VLAN0005 sent Topology Change Notice on Fa0/33
3w2d: STP: VLAN0005 Gi0/1 -> blocking
3w2d: STP: VLAN0003 Topology Change rcvd on Fa0/5
3w2d: STP: VLAN0005 new root port Gi0/1, cost 59
3w2d: STP: VLAN0005 Gi0/1 -> listening
3w2d: STP: VLAN0005 heard root 24581-000b.be04.8f80 on Gi0/1
3w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/33, changed state to down
3w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to down
3w2d: %STANDBY-6-STATECHANGE: Standby: 5: Vlan5 state Active -> Init
3w2d: STP: VLAN0005 sent Topology Change Notice on Gi0/1
3w2d: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/5 VLAN3.
3w2d: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/5 on VLAN0003. Inconsistent port type.
3w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/33, changed state to up
3w2d: STP: VLAN0001 new root port Fa0/33, cost 55
At this moment the catalyst are in loop i think.
If I disconnect the both catalyst, the catalyst 1 works
fine again.
Can anybody help me
05-27-2003 07:14 AM
The error messages suggest that the interface has an inconsistent port type and is being held in a spanning-tree blocking state until the port type inconsistency is resolved.
Verify that the configuration and operational state of the listed interface and that of the interface to which it is connected have the same mode (access or trunk). If the mode is trunk, verify that both interfaces use the same encapsulation (ISL or 802.1Q). When these parameters are consistent, spanning tree will automatically unblock the interfaces.
Hope this resolves the issue.
05-28-2003 04:43 AM
Dear Member,
first off all, very much for your Help.
Could you tell me, whether i have to allowed or disallowed Vlans for Trunks?
Thanks for your Help
05-28-2003 05:08 AM
I'am suprised about your configuration for the port fa0/5
If it's a trunked port, why haven't you got the line "switchport mode trunk" <- ?
Secondly, it seems that you have a loop when you connect catalyst 1 and 2 behind gi0/1 and behind fa0/5 -> topology changes.
Is it normal ?
Regards.
05-28-2003 06:12 AM
on the Ports fa0/5 are be connected a 3 Com Switch with one Cable in each
Switch.
The catalyst are connected together over the gi0/1.
My goal is it to attach a SWITCH to both Catalyste (Redundance).
I do not know, which is the correct Configuration for this.
Best Regards
05-28-2003 09:22 AM
You should have a VTP server. I suggest making both VTP servers since this is a high-availability model. All other switches should be VTP clients. Make sure you have the same VTP domain on the other switches.
Note: if both are VTP server then you must add, change and remove VLANS from both. Use the "vlan database" command (from exec mode) to manage VTP.
This appears to be PVST (default). If you decide to do MST set your revision number on the primary to the highest revision number and set the rev on the secondary to the second highest. Make sure your revs are set well above any other connected switch.
Don't try to trunk to a 3com switch. Eliminate the encapsulation and simply use the switchport access vlan 3 method. One of the 3550's will block on port fa0/5 because this is a loop. Do not enable portfast on fa0/5.
As someone already mentioned do not use switchport access on trunk ports. This can cause CAM flapping by advertising MAC addresses across multiple VLANS if you run fastetherchannel with trunking. You need to remove the "switchport access vlan X" from any trunk interfaces. Use the "switchport trunk native vlan X" statement instead. You must also include the "switchport mode trunk" statement.
If you decide to replace the 3com with a 3550 12G you would want the 12G to be spanning tree root and the primary 3550-EMI secondary root, and so on. Otherwise if the root is the 3550-EMI the other 3550-EMI will block the 12G uplink.
Why are you using the 3com to bridge these together? Do you have clients or servers hanging off the 3com switch on VLAN 3?
