Hi Techies,
One of our customer wants to replace AS5400XM being it is EOS/EOL , and looks for a replacement product which basically should
support
· SS7 to SIP ,· SIP to SS7 , SIP to SIP , SS7 to SS7
The parameters required for the gateway mainly are:
· DNIS based Routing,· CLI based Routing , BNUM based Routing ,Trunk based Routing , Port based routing , Peer based routing
· Multiple match rules from above based routing
The SS7 gateway MUST support alphanumeric Routing Numbers (RN), used in number portability. If possible we would also like lookup based routing (lookup to a number portability table which can be xml based lookup).
when I check with cisco they replied cisco exited from ss7 business and the above requirement cannot be supported.
but one of my peer suggested me that SS7 connections can be terminated on a cisco voice router
--------------- STM4-if(Voice router)------->ONS3 with multiple E1 -----pgw
can you guys please give some of ideas and suggestions on this.
Basically the client is an ITSP with multiple TDM connections , in case of going for above solution where will be the pvdm resources be located
to support 2000 calls
