05-27-2022 05:00 AM
I'm having trouble with two newly purchased RPS 2300.
When they go into power supply mode the fans start. But when the main power returns, the fans continue to run loud for hours.
What to do?
05-27-2022 06:36 AM
- Check status LEDs on the device do you have any 'negative indicators' ?
M.
06-07-2022 07:54 AM
The LEDs do not give particular indications. The strange thing is that we took two rps and on both of them the same thing happens. The fans start and when the power returns the fans continue to run strong for hours. Isn't there some command on the switches that I need to give?
