serial 4T not detected in 2621
ahmadbilal
I have a cisco router 2621 when i install the module cisco NM4T it is not detectetd. following are the outputs.i have tried IOS 12.2.15T15 & 12.3
booting up:
smart init is sizing iomem
ID MEMORY_REQ TYPE
0000A2 0X00103980 C2600 Dual Fast Ethernet
000054 0X0004E480 4T Mueslix Serial
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003FB470
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 6 percent iomem. [4Mb/64Mb]
%PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 84)) is not supported on this image.
Please issue "show diag" in fully loaded IOS image
to get the PA's information and verify if it is supported
show diag:
Slot 1:
Unknown (type 84) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision H0
Serial number 21926189 Part number 800-02314-02
FRU Part Number: NM-4T=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 54 01 01 01 4E 91 2D 50 09 0A 02 00 00 00 00
0x30: 88 00 00 00 00 10 07 00 00 05 FF FF FF FF FF FF
thANKS
jolmo
Level 4
Level 4
According to next document:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8b.html
the NM-4T module is not supported at 2600 series (except 2691 model, see Table 7 Supported Platforms).
I'm having the same problem with NM-4T with a 2610 xm router . I would like to know what is the correct card to use.
Andrea
Hi Andrea
I think the best choice (and perhaps the only one) is to use a Network Module NM-2W with two WAN Interface Cards WIC-2T, so your router will have 4 serial ports.
Here you are some info about this cards:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a00800b1155.shtml
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b0858.shtml
linuxfish00
The Serial NM-4T physically fits perfectly in my router 2621. I bought them because the seller assured me they work with any 2621 IOS. I noticed on cisco's website, under platform support for the NM-4T, that it is not supported.
However, is there a workaround, or a 16MB IOS that will allow me to use the NM-4T? I need to practice with it in a non-production environment.
