hi,
Can any one tell me Y is the status of DSR=down.when as i am able to ping the ip of the other end ip sucessfully.(DCD=up DSR=down DTR=up RTS=up CTS=up).
Router # sh int s3/2
Serial3/2 is up, line protocol is up
Hardware is M8T-V.35
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation FRAME-RELAY, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
LMI enq sent 1329, LMI stat recvd 1330, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 77/0, interface broadcasts 0
Last input 00:00:03, output 00:00:03, output hang never
Last clearing of "show interface" counters 03:41:33
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
1425 packets input, 27700 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1505 packets output, 50632 bytes, 0 underruns
0 carrier transitions DCD=up DSR=down DTR=up RTS=up CTS=up
thanks
