serial interface(dce end) problem on 4000 series router
manumohan200
I have given ip address & clock rate on the serial interface which is the dce end. the line is up but the protocol is down.
the configuration is
interface Serial0
ip address 30.0.0.1 255.0.0.0
clockrate 64000
I have done the following test.
Router#test interfaces serial 0
... Failed - not connected problem
1 interfaces: 0 passed, 1 failed, 0 skipped, 0 untestable
interface status
Router#sh int serial 0
Serial0 is up, line protocol is down
Hardware is HD64570
Internet address is 30.0.0.1 255.0.0.0
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input never, output 0:00:03, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
146 packets output, 5641 bytes, 0 underruns
0 output errors, 0 collisions, 43 interface resets, 0 restarts
80 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Is it a hardware problem?
Need I do any configuration with clocking like invert clock rate or like that.Here two routers are connected back to back.
Harold Ritter
Do you use the same encapsulation (HDLC) on the other router?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
smif101
Level 4
Level 4
Have you done the loopback test that I described in a previous message of yours a week ago?
