Setting a lab 7206 to facory defaults
DELL ACORD
Is there a way to reset a 7206 router to factory defaults so that the startup-config. and run-config. has been set back like it was when the router was taken out of the box beside typing the no command for each line of the running-configuration and then coppying it to the startup-configuration?
DTA
srittenberg
there are hardly any setting on it when you first receive the 7200 router. so if you really wants to do this, you may as well write erase, and type setup start all over.
MickPhelps
Very simple:
write erase
reload
Do NOT save the configuration if it prompts you to.
Mick.
