you can stack these switches together, but if you require unified routing across the stack, your lowest common denominator is RIP (v2). The WS-C3750-12S-E can do OSPF. You cannot stack the two switches together and run OSPF on the stack.
This information is based on IOS version 12.1(11)AX, check out this link for additional technical specs:
