Switches and routers recommendation for a call center
Hello to all
We are looking to set up 2 call centers, each in different cities, both will use ip voice
one call center will have 250 phone operators, and the other one will have 150 phone operators
Which routers and switches would someone recommend to use?
5 Replies 5
Leo Laohoo
1.  What is the budget?
2.  What is the WAN link per site?
We are looking at 50mb for the site with 150 phone operators, we are still not sure about the other one, as always budget is tight
thanks for your help
What is the budget for the site with 50 Mbps WAN speed & 150 phone operators?
I am sorry but as you must understand budget is confidential
sorry
The budget will help to recommend SMB-grade router & switches or enterprise-grade router & switches.
