TOPOLOGY GROUPS PROBLEM - WITHOUT SOLUTION?
Hernan Moya
I have consulted in a pair of opportunities like solving a problem that I have with Topology Services.
At the moment the tool does not work and appears the Page error not found. It must to a problem with the file httpd.conf?
It is possible to be solved without having to reinstall all the Campus Manager again?
If I reinstall Campus Manager, topology groups will be lost?
Thank you very much.
drolemc
Level 6
Level 6
Is your Campus Manager not loading? Unfortunately, from your post, it's not too clear about the kind of problem you are facing. Anywys, if it is a Campus Manager loading problem, it might be due to some java plugins installed on the system. We had to uninstall all java plugins, clear the cache and then reboot the system to solve the Campus Manager display problem.
