Understanding Power Supply Specifications
Kevin Kilgore
I'm looking at Power Supply PWR-C1-715WAC.  The Input current is 10-5 A.  So does that mean 10A for 120V?  If I have 2 of them, does that mean 20A?
Leo Laohoo
It's a dual-voltage so it will support 110v and 220v.
So this means you have two power feeds of 10A for each PS.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, up to 10A for 120V, and up to 5A for 220V.  (Leo answered this, but I also wanted to note actual amperage will depend on active power usage of the device(s).  Further if you have two power supplies, each can draw up to its maximum wattage [amperage] but also with two active, each will draw less as each should provide half the power.  [Power draw will also vary if using a power stack.])
