Using ACL for security control for Internet WAN router?
beiyanlong
Hello Guys,
I have a design question. I'm using a Cisco ASR1K as my Internet facing DMVPN Hub router. I know I should place a firewall in front of it. But why not just use built-in ACL to open necessary ports (i.e. UDP 500, 4500 and ESP) on the port? My ACL is also controlling from which public IPs traffic can come in.
Would it be sufficient? If not, what's the justification for placing a more advanced firewall? Any thoughts are welcome!
beiyanlong
Any comments, thanks in advance!
Joseph W. Doherty
The usual argument for using a FW is it's a device built for security, and is "better" for any publicly connected interface. Of course, a FW adds cost and sometimes creates a throughput bottleneck.
Personally, I don't believe a FW is warranted in front of a VPN router, because, as you note, you can lock down the publicly connected interface.
Interestingly, I've seen Enterprises have a FW in front of their VPN hub router but not have a FW in front of each branch VPN router. Since a VPN branch router also provides a path into the Enterprise, I've never heard a good explanation why a FW is a "must" at the hub but not also at the branch.
BTW, the company I'm working for does have VPN hub routers with direct Internet connections.
Also BTW, if you want to further harden a VPN connected router, you can also place its publicly connected interface into its own VRF. This means unless the traffic comes through a VPN tunnel, you can preclude it from routing internally.
I totally agree and on the same page as you, i already used fVRF for Hub and Spoke Internet connections since they are just being used as underlay network. We have policy that all spokes traffic need to be centralized, which means Hub is pushing a default route to all spokes. That's why I feel it's making more sense to add Firewall after VPN Hub router and before they enter my datacenter core layer.
As always, i appreciate your input but i'm open to hear any other opinions!
