Using CW2K to upgrade 1924's
bw3481
I want to use CW2K to perform IOS updates on 1924 switches, is there any documentation out there on the process. Will CW try and reload the switch automatically ? Is there a specific IOS file (i.e. .tar, .bin) that CW requires?
Ben
rmushtaq
Level 8
Level 8
Not sure what is the version of RME in CW2K that you're using but have a look at: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_4/u_guide/ug_upgrd.htm for the details on software upgrade using RME.
